THIRD GEN Formula LS1 SWAP
However...if you really just want the motor and trans pull out... Look to buy:
- motor mount plates
- trans crossmember
- torque arm
- fuel pump upgrade
- re-gear if going from auto to manual
- hoses for various things
- a bunch of relays and some wire
- headers if you arent using stock manifolds
- some exhaust parts and fabbing
- intake ducting and a filter
That should get it running and driving. There are probably a handful of things I left out. Basically what my long rambling post is saying... I agree with the above. The small stuff that I cant even think of, that Ive already bought are the things that add up. Then if you are like some of us..you cant stop at a simple swap. Next thing you know you are getting springs, new shocks, poly bushings for everything, etc etc..
If you are handy, and decent at fabricating, you can cut the cost big time. If you want to make your own stuff, you could pull this swap off fairly cheap i think. Its all in how much you want to buy or make.
Justin
