T-56 experts, have ?s
Old Jun 28, 2006 | 10:55 AM
Stampede4ever's Avatar
Default T-56 experts, have ?s
What is the length of the input shaft, and what is fords's length, can the rear housing be changed to ford specs, and where to buy parts from?
What are the differences from the pre 99's and 99's and up?
Thanks.
Old Jun 28, 2006 | 03:03 PM
'JustDreamin''s Avatar
I know I don't know your answers. Not sure that anybody on here will.
I'd suggest you call a couple of folks, either Rockland Standard Gear or Keisler Engineering. Search the web, you'll find their numbers. They both deal in T56's and should be able to help you out.
'JustDreamin'
Old Jun 28, 2006 | 03:09 PM
Slo_240sx's Avatar
I have no clue but try the manual transmission section.
Old Jun 28, 2006 | 11:10 PM
PBB's Avatar
PBB
T-56 Input shaft lengths:
LT1: 9-1/4"
LS1: 10-3/4"
Found that info here: http://www.mackstrans.com/TremecID.html
Couldn't find the length of the Ford T-56 inputs shaft but the Cobra used a 10 spline input shaft versus the Viper/F-Body 26 spline.
http://www.t56rebuilds.com/subpage1.html
http://www.5speedtransmissions.com/6sppage.html
If your looking to put a GM or Viper T-56 into a Ford, sounds like a good bet for the tailshaft housing problem just to use the GM/Viper tailshaft and get a different yoke and shorter driveshaft.
http://mustang50magazine.com/techarticles/17658/
Old Jul 9, 2006 | 10:24 AM
the.erinyes's Avatar
Default T56 in GTO using with Camaro
Is the shifter location for the GTO T56 the same as the Camaro/F Body shifter location?
