In tank pump wiring?
Old Jun 29, 2006 | 01:39 PM
pt67camarols1's Avatar
Default In tank pump wiring?
Guys ,I like to know what I should be aware of when wiring for the in tank pump. That kind of scares me electrik wires being in the tank with gasoline.
Thanks
Old Jun 29, 2006 | 01:43 PM
bczee's Avatar
Secure connections and routing only were they should be or not be. Follow manufactors and OEM guide lines and instructions.
I had the same fear when I converted my 84 Z28 to a intake pump. I am still alive after 10+ years.. (crossing fingers now)
Old Jun 29, 2006 | 02:49 PM
I dont know any OEM guidelines. My wory is that when i build a sump pump how careful I have to be with the wires connecting to the pump. Electric inside tank and gasoline being conductive scares me.
Old Jun 29, 2006 | 04:05 PM
super_kev's Avatar
I had the same fear as you, but you should have no problem with anything, as I'm told gas is a good insulator. Check out this discussion on that issue: Is Gasoline Electrically Conductive?
Old Jun 29, 2006 | 09:52 PM
Thank you man. That was a good read.
Old Jun 29, 2006 | 09:59 PM
leonpiper69's Avatar
on a side note: anyone worried about voltage in a tank, think about this ... the fuel level sender is a 12 volt circuit and that has never raised an eyebrow!!!!
