which ecm
Old Jul 13, 2006 | 04:28 PM
ls1perfcar?'s Avatar
Default which ecm
Im building a 68 chevy swb truck and im puttin a 6.0 lq9 motor out of a escalde in it. The problem is where do i get the wiring harness for the motor and what ecm can i run? do i need to have the 04 ecm or can i use other years?
Old Jul 13, 2006 | 07:51 PM
Scooter70's Avatar
You can use just about any Gen3 GM V8 PCM from 1999-2004. For the wiring harness, you can modify a stock one for yourself or have it done by a company like Speartech. Or you can have Speartech build you a completely custom harness.
Are you using the electronic throttle body? That will change a few things.
