Power Booster Push Rod Adjustment Question
Old Jul 13, 2006 | 09:42 PM
69LS1SixSpeed's Avatar
Default Power Booster Push Rod Adjustment Question
Question...I have an universal Stainless Power Brake Booster (7"). I need to shorted the push rod on the master cylinder mount side. Currently, it's about a 3/16 inch too long which is pre-loading my master cylinder. Attached is a picture of the booster. It has a small nut and then a larger right behind. I tried turning it both directions but it didn't seem to change the depth of the end of the rod. I tried placing a couple on washers on the bolts to move the master farther away but I don't like that approach. Are these booster push rods adjustable? Inside on the back side of the booster is a threaded 3/8 bolt with a nut that I attached the clevis rod and it seems to be adjusted correctly. Please advise and thanks in advance for your input.
Old Jul 14, 2006 | 03:35 AM
jannes_z-28's Avatar
There should be a rubber gasket between the M/C and the booster, it will take up the space you need. You have that?
Jan
