ls1 to ls2 swap in 98 ta
Old Jul 22, 2006 | 11:41 AM
crzytown69's Avatar
Default ls1 to ls2 swap in 98 ta
i have a 98 trans am with an ls1 w/4l60e i was looking to see what all you had to do to swap in a ls2 motor... like one off ebay out of a goat or cts i know you can build one with the block and what not but im just looking to refresh the whole thing ... ls1 out an put the ls2 in i know it bolts up but i am just wondering about the belt driven acessories and the wiring... thanks a bunch im going to search some more
Old Jul 22, 2006 | 10:30 PM
99c5vert's Avatar
I don't know exactly... when LS2 first came out, it seemed like knock and cam sensors were going to be issues to address... there used to be alot of threads at corvetteforum, in the C5 Tech secion on it.
Old Jul 23, 2006 | 07:05 PM
crzytown69's Avatar
thanks
Old Jul 24, 2006 | 09:02 PM
71chevytruck's Avatar
september 2006 pop hot rodding states that the wiring harness and computer is the only differences.If you can find an early 24x version of the ls2 then all u would need are wiring adapter harnesses from a company like katech engine development.If u can only get the newer 58x version u will need a new comp or swap out the 58x reluctor wheel on the crank to the 24x version. katechengines.com for the harness I hope this helps
