rewiring two sensor connectors
Old Aug 6, 2006 | 04:11 AM
fouz65's Avatar
Default rewiring two sensor connectors
i guess when they pulled the engine at the yard they got pulled out. i need to put em back in the plug but dont know which wire to which pin in the plug. enigne out of a 2002 camaro.
one is the sensor in the oil pan. 2 wires.
the other sensor is (knock sensor or crank angle im not sure) the one thats right behind the starter. 3 wires. which color to what pin? any help or a point in the right direction would be greatfull.
Old Aug 6, 2006 | 11:32 AM
patrick_rodgers's Avatar
Per the 2000 Camaro shop manual
Crankshaft sensor (lock tab at the top A is to the left) looking head on into the plug
A = Dark Blue / White
B = Yellow / Black
C = Light Green
Oil level sensor (lock tab at the top A is to the left) looking head on into the plug
A = Brown
B = Black / White
Old Aug 6, 2006 | 02:37 PM
fouz65's Avatar
thats the colors i got so, thank you very much.
