a/c questions
Old Aug 6, 2006 | 01:14 PM
92slowmaro's Avatar
Default a/c questions
ok i am in the process of putting my 92 camaro a/c compressor on my ls1 with some custom brackets. anyways my harness i had made for my ls1 only has the clutch engage and disengage connector and not the pressure switch. sould this be a problem?
Old Aug 6, 2006 | 01:29 PM
LS1MCSS's Avatar
I have an f-body compressor on my car too. I bypased the pressure switch that is on the compressor. You will have the cycle switch that is mounted on the dryer.
Old Aug 6, 2006 | 01:47 PM
92slowmaro's Avatar
ok so basically dont worry about it? just plug the new harness in and provided that the a/c harness from the control head to the dryer and what not is all good then i will have no problems?
