Oil Pans
Old Aug 6, 2006 | 03:49 PM
72Cutlass's Avatar
Default Oil Pans
I plan on putting a GTO LS2 and 4l60E in my 72 Cutlass and was wondering if the front sump oil pan would interfear with any of my steering linkage?
Old Aug 6, 2006 | 05:35 PM
93Polo's Avatar
The a-body guys are running rear sumps, truck, f-body or Cts-v pans depending on the mounts used/ground clearance for the car.
Old Aug 7, 2006 | 10:43 AM
72Cutlass's Avatar
Thanks
Old Aug 7, 2006 | 03:13 PM
leonpiper69's Avatar
that cutlass is front stear, right? im useing a stock f-bod pan but the first gens have rear stear so i had to notch the pan . if you have front stear wich im pretty sure you do (my chevell did, almost same car) you shouldnt even have to notch it.
Old Aug 7, 2006 | 05:19 PM
chicane's Avatar
Look at the ATS pan... the are a sponser here >>>>>
