97 Corvette fuel rails
Old Aug 8, 2006 | 03:23 AM
alky's Avatar
Default 97 Corvette fuel rails
I found these return style fuel rails at Rockauto for $193. Does someone have a picture of this fuel rail?
I have a 2002 Ls1 going into a '69 camaro and need a return style fuel system. I'll be using a sumped tank, weldon 600a pump, with an Aeromotive reg.
TIA
Denny
Old Aug 8, 2006 | 09:03 AM
70 LS1's Avatar
Conversion master
If you are using an aeromotive regulator then you don't need the 97 fuel rail. The return rail has the regulator built in. The later LSx's use a regulator closer to the tank with a shorter return line. All Fuel injection needs a return line of some kind.
Old Aug 8, 2006 | 01:19 PM
alky's Avatar
Thanks, I think i'm going to go with the billet rails.
