pcm question
Old Aug 13, 2006 | 09:40 PM
92slowmaro's Avatar
Default pcm question
ok so im swapping my ls1 into my 92 camaro. now the pcm has a wire to power the fuel pump. if i dont use this wire and just use my existing 92 system for the fuel. will this set a code in the pcm? will it cause a problem or will everything be ok?
ryan
Old Aug 13, 2006 | 10:40 PM
StngKlr's Avatar
Your PCM should have a wire to "turn on" (not power) the stock relay for the fuel pump. You will need to hook this up if you want everything to function correctly.
