'97+ 3000gt?
Old Aug 14, 2006 | 03:14 PM
Fuzzylogic's Avatar
Default '97+ 3000gt?
Anyone done the swap? The VR4s are pretty cool cars, but I think a V8 would make it just a bit cooler. Not sure on how feasible it would be to keep the AWD, but what do you guys think?
Old Aug 14, 2006 | 03:22 PM
WhiteStripes's Avatar
If you could keep the AWD you'd be god. Lol but no I bet that's not possible. You'd have to find all the different parts that would fit. I mean if somone can stuff an LS1 into a 240SX this swap should be easy.
Old Aug 14, 2006 | 05:15 PM
CMcCarthy's Avatar
The VR4 gearbox is notoriously weak, so keeping it AWD even if you could solve the space constraints would be almost impossible.
What you'd essentially be doing is a FWD to RWD conversion, with the exception that the 3000GT already has provisions for a driveshaft and a rear differential. Its unlikely that the 3000GT has sufficient front-to-back engine compartment clearance for a longitudinally mounted V8, and hood clearance would also be an issue.
