ls1 help someone
Old Aug 15, 2006 | 02:18 AM
1442's Avatar
Default ls1 help someone
i have my motor in it will start but not turn off at ignition, any ideas will help
Old Aug 15, 2006 | 09:26 AM
crainholio's Avatar
Check your wiring.
Old Aug 15, 2006 | 10:27 AM
LS1Cobra's Avatar
Check your alternator wiring. If your alternator wiring is wrong it could feed back the voltage to your ignition relay and therefore keep the car running when you turn off the key. GL
Old Aug 15, 2006 | 12:30 PM
RFERG43's Avatar
Most likely you have the PCM ignition start input hooked to constant 12V.
