Hot fan relay
The fan turns on and off ok but I noticed the relay is hot to the touch.
The #87 spade which goes to the fan is even hotter than the relay
Anyone know what could be causing this ?
My connections are on the relay are:
#30 - 12v
#86 - fan switch
#85 - ground
#87 - fan
Jack
#30 - 12v
#86 - fan switch
#85 - ground
#87 - fan
Jack
what size wire are you running?
You need much bigger wire from the relay to the fan. And the ground doesn't need to be #10. Think of a relay as an electrically operated switch. All it does is connect the input and output which are high current and therefore need to be big cables. The control circuit (ground and fan switch) are low current, and can both be #16.
Also, make sure that your spade connectors fit on the lug of the relay really tight. Once you upsize the cable for #87, you might think about squeezing the female portion of the spade connector a little tighter (may need to do it with the terminal on the relay) for a better electrical connection. Heat is a sign of a poor electrical connection.
So, in summary, you should:
1.) Replace the relay to fan cable with #10 gauge.
2.) Crimp and SOLDER the terminals on the the cable.
3.) Install the terminal on the relay and ensure its TIGHT.
'JustDreamin'
The fan actually came with that 16 gauge wire, both + and - wires are already connected internally to the fan motor. Should I re-do that ?
