Gas tank question
Old Aug 27, 2006 | 08:17 PM
chickenman97's Avatar
Default Gas tank question
Guys
For the 68 camaro that I am doing a swap on, I have a question.I am planing on useing a in-line pump. Could I use a new tank and weld a 3/8 fitting on the bottom middle of the tank?? That way it should gravity feed the fuel pump.What do you think??
Thanks,David
Old Aug 28, 2006 | 03:16 AM
OldSchoolFormula's Avatar
And how do you plan on keeping it covere in fuel during acceleration, braking, or cornering with a lower tank? (like 1/2 a tank....)
Old Aug 28, 2006 | 07:15 AM
shanekennedy's Avatar
i used this setup for my 68:
http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
http://www.thedetailzone.com/Tanks%2...%20Install.htm
Old Aug 28, 2006 | 04:09 PM
phoenixdawg's Avatar
Default how did the tanks inc set up work for you
I need to do the same for my conversion, did you use a stock tank?
Old Aug 29, 2006 | 07:06 AM
bought a stainless stock tank from classic ind. (they're running the 20% off sell right now)
i mounted the tanks inc setup on the passanger side of tank so i could keep original sending unit in the middle. there's not room above the tank for the hoses & fittings, once tank is mounted to car. i plan to add some wedges above the tank to drop the front of the tank down about an inch.
