72 camaro mounts LS1
2) try other Frame mount (good idea anyway to get correct engine height) from other models and engine along with different motor mounts (can be different heights also. EnergySuspension makes a Tall and Narrow and a standard short/wide mounts)
3) Fab up some new frame mounts (JohnB's Monte site has a good one design to start wtih.)
Good luck
It took a few hours to cut, drill, tap and grind to create my mounts with standard hand tools. I powder coated them myself. $10.00 invested for the steel.
from the Energy Suspension site.
Short & Wide Type Early Style General Motors Performance Polyurethane MOTOR MOUNTS
Two Types- short & wide and tall & narrow are available, and in two finishes:
Short & Wide Type:
#3.1114 has a zinc finish.
#3.1115 has a chrome finish.
Inside Width- 2 5/8"
Height Base to Bolt Center- 1 3/4"
Replaces O.E. part numbers: 3990914, 3960768, 6258154
Replaces aftermarket numbers: 2267, 2285, 2142
This type / size chrome motor & transmission mount set is #3.1133.
This type / size zinc finish motor & transmission mount set is #3.1120.
Tall & Narrow Type Tall & Narrow Type:
#3.1117 has a zinc finish.
#3.1118 has a chrome finish.
Inside Width- 2 3/8"
Height Base to Bolt Center- 2 3/16"
Replaces O.E. part numbers: 3962740, 3990918, 3962748
Replaces aftermarket number- 2283
This type / size chrome motor & transmission mount set is #3.1134.
This type / size zinc finish motor & transmission mount set is #3.1122.
Tyler
so i went back to my original mounts and drilled new holes.
