Throttle cable part numbers? Search is broken
Thanks
You can also use GM #12565559 per the LS1 Engine Kit Installation Guide with minor Mods to it.
It is 36".. it is more than long enough. could get by with a 28-30" from the amount that I have routing around.. I comes out of the firewall, makes a turn to the passenger side, then just about at the rear most the coil, it turns to the T/B.. so you can see there is a lot of extra with the Lokar 1000LS1 cable.
BCZEE
I used one of the factory holes in the firewall (the upper Square one), but i did have to use some larger washers, as the hole that I use was just a bit larger that the Lokar lock nut and end.
