k-member
Old Sep 24, 2006 | 01:42 AM
ROUDA's Avatar
Default k-member
I need to know if the k-member on a v6 is the same as a v8 and or if the motor mounts are different how do you change the v6 mounts to hold a lt1.
I am going from a stock 3.4 v6 k-member to an lt1 kmember cause I an doing the lt1 swap in the car and I am just getting the k-member off the lt1 and useing all the other parts off the v6 such as spindles and brakes rotors , but if I dont have to do anything besides switch the mounts it would be easier than putting everything on the v6 k-member to the lt1 k-member.
Old Sep 24, 2006 | 02:30 AM
Genesis_26317's Avatar
You should also post this in one of the advanced tech forums. What year v6 are you talking about anyway?
Old Sep 24, 2006 | 10:48 AM
ROUDA's Avatar
ill try to move it there. Its a 1995
