GTO LS2 engine into a '68 Camaro?
Old Sep 28, 2006 | 09:34 PM
Infamous's Avatar
Default GTO LS2 engine into a '68 Camaro?
Any problems getting it in there? I got a line on one with a T-56 trans that comes with everything imaginable including the kitchen sink for $8500 and it only has 4025 miles on it. Is that a reasonable price? It's being pulled from an '05 GTO.
Thanks for any help you can give me.
Tony
Old Sep 29, 2006 | 12:17 PM
01WS6/tamu's Avatar
damm lotta $$
Old Sep 29, 2006 | 12:21 PM
eagleuh1's Avatar
Default Is that at Schramm?
Good if everything is there. Get everything you can from them.
Old Sep 29, 2006 | 01:17 PM
Infamous's Avatar
I was told it does not come with the Drive-By-Wire cable that plugs into the gas pedal and harness or the clutch master cylinder.
And yes...it's from Schram. Are they any good?
Old Sep 29, 2006 | 09:26 PM
PRAY HRD's Avatar
an '06 LS2 from a GTO wiht 2988 miles, clutch, and flywheel just sold on here for $3000 2 days ago. i'd wait and find a better deal than that. you can also pick up a low mileage, or rebuilt t-56 trans for under $1500. i'd wait and put the other $3000-$4000 towards something else. bottom line, if you can hold off, you can get a better deal than that. hell, you could even pick up a sub 50k mileage motor for $2500 and have it gone through and add forged pistons & rods for around $2000, add a decent head/cam pkg maybe for another $2500 installed & tuned, and still have $1500 left to put towards a decent 6spd plus a little extra, but you'd have a much more potent motor that's 100% fresh. just an idea. good luck with whatever route you go.
Old Sep 30, 2006 | 10:31 AM
Steve68's Avatar
What are you doing here?, you MI fool, come,come, to the dark side, we will take care of you!!!
Old Oct 2, 2006 | 12:10 PM
The Red Baron's Avatar
There are 3 plugs that come off of the LS2 E40 ECM. Two go directly to the motor and trans. The third runs through the firewall to the dash fuse box. You have to cut a 12" by 12" hole in the firewall to pull it. This is the third harness:
That's not a bad price to get everything basicly brand new. Look at what people are asking for complete 5 year old LS6 motor and trans combos for comparison. That is what the LS2 motor best compares to.
Old Oct 3, 2006 | 01:32 PM
77ZETA's Avatar
I got my LS2 from Schram, They are good to deal with.I think the price is right.
Old Oct 6, 2006 | 11:53 AM
mzrico's Avatar
The price is good. I got my LS2 from them and no regrets. The Oil pand won't work on your 68 (you need the LS1 oil pan from a 1998-2002 Camaro). You will need to pay a good electronics guy to help you with drive by wire set up ( I payed $900 for all the engine electronic re-wire a bit much but It pays to have the experts do it). The AC compressor has hose ports to the side you'll need to adddress that to cleas the frame.
Old Oct 6, 2006 | 11:56 AM
mzrico's Avatar
You may have seen this, but just in case (hope it helps).
https://ls1tech.com/forums/showthrea...ght=LS2+Camaro
