No tach signal
Old Oct 3, 2006 | 05:40 PM
dsrour's Avatar
Default No tach signal
Don't seem to have tach signal, at least I can't get tach to work. Tried a couple of tachs. I have a speartech harness using white wire. Any ideas. I know its a 4 cyl signal
Old Oct 3, 2006 | 08:54 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Some applications, tachs, etc. need a pull-up resistor to "boost" the signal.
Try a 10K resistor with one side hooked to your switched 12 volts (ignition switch) and the other side tied to where the wire from your tach is hooked to the tach wire from the harness.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Oct 3, 2006 | 11:44 PM
AaronH's Avatar
Default Tach
Got the same info from John previously. Went to Radioshack and purchased five resistors for a dollar and it works perfectly. Thanks John
Aaron
