fuel system in mustang
Old Oct 25, 2006 | 09:23 AM
GlennNo50's Avatar
Default fuel system in mustang
Doing a LS1 conversion into a mustang but want some extra fuel for the future. Already have a 255lph pump what size fuel line and what else would we need as far as regulators and such. The motor is a 400hp 2000 so I assume it is a returnless system. So I am thinking:
255lph pump>>>>-8 feed line>>>>>Corvette filter>>>>>regulator>>>>>power products fuel rails>>>>>>30# SVO injectors..
Am I misssing anything?
Old Oct 25, 2006 | 10:38 AM
Brains's Avatar
You can run a returnless if you like, or a return style. Its up to you, just set up the PCM fueling tables appropriately. If the fuel pressure at the rail tracks your manifold pressure/vacuum, you set the PCM fuel injector table as a flat line (like a 97 vette). If you run a returnless with a static rail pressure, you set the table to increase pulse width with a drop in vacuum (like the newer cars).
Old Oct 25, 2006 | 11:53 AM
GlennNo50's Avatar
Will this be something a tuner can do when have the computer tuned for our mods? Or will it automatically increase the pulse width already since we have a 2000 computer? I believe we will go returnless.
Old Oct 25, 2006 | 02:33 PM
Brains's Avatar
The 2000 will already have the table set for a returnless system, but yes - your tuner can set it however needed.
