Oil Pressure sender/switch?
I don't remember off the top of my head if the PCM even inputs this.
Will HpTuners/EFILive display the values that it is reading?
I broke it off on my motor the other day and I am debating on getting another one if there is no use.
If you really don't care to log the pressure and just want a gauge, you can put a mechanical or electric sender in the motor and just run it to an Autometer gauge. I put mine in the port by the oil filter and plugged the hole in the back of the block.
I don't have any gauges, so HPTuners through an 8" touchscreen contains all my "gauges"
What pins on the PCM did you hook the sensor to?
Any pictures of the touchscreen I really want to install one as well, but it's not in the budget at the moment.
