Alternator and AC connectors.
Old Oct 29, 2006 | 01:51 AM
crafty888's Avatar
Default Alternator and AC connectors.
My plugs are not labelled, can someone please confirm which one of these is correct:
ALTERNATOR
Looking at it from the DRIVERS side with the front of engine <<< way
A - top
B
C
D - bottom
or
D - top
C
B
A- bottom
AC
Looking at it from the PASSENGER side with the front of engine >>> way
A - top
B- bottom
or
B - top
A- bottom
Old Oct 29, 2006 | 02:21 AM
gmax111's Avatar
huh?
i know they are not labled a b on the A/C and i dont think they are labeled abcd on the alternator... so how do i know what is what... ? Go to autozone and find the plug to the alternator there... it should have colored wire on the plug then just match it up to the harness...
And for a/c are you asking which is low pressure/ high pressure?
Old Oct 29, 2006 | 08:58 AM
crafty888's Avatar
What I need is:
ALT
Pin B - I've seen other threads like this one https://ls1tech.com/forums/showthrea...ght=alternator but I am not 100% sure which one is Pin B......is it second from top or second from bottom?
AC
Pin A for Clutch
Pin B earth
Which is which.....
Old Oct 29, 2006 | 09:12 AM
bczee's Avatar
Pin B for the Alternator would be the second one from the Fender side looking towards the engine.
D
C
B <=
A
Old Oct 29, 2006 | 09:38 AM
crafty888's Avatar
Good one.... so ALT is covered.... anyone got a tip on the AC clutch.... which is +ive, which is earth?
Old Oct 29, 2006 | 06:37 PM
crafty888's Avatar
ttt..... anyone?
Old Oct 30, 2006 | 06:44 PM
crafty888's Avatar
Anyone....
AC connector has two pins
Pin A is positive from AC clutch relay
Pin B is earth
Which one is Pin A - top or bottom.
