no fuel after startup?
Old Oct 31, 2006 | 08:45 PM
nuckifuts's Avatar
Default no fuel after startup?
my car will start up for two to three seconds and then shut off. if i lightly mist carb cleaner down the throttle plate it will stay running. i tested fuel pressure which is 55lbs and it has good flow. it does have injector pulse on the cylinder i tested. any thoughts? thanks, rich.
Old Nov 1, 2006 | 12:47 PM
Jhankinson's Avatar
VATS...either reprogram and disable it or get a VATS Module
