Looking for a conversion fitting for the clutch master
Old Nov 3, 2006 | 04:28 PM
Elec87's Avatar
Default Looking for a conversion fitting for the clutch master
I thought I saw a while back that somone was making a roll pin style fitting that would go into the f bocy stock clutch master and convert it to either a -3 or -4 fitting... I am looking to adapt a -4 line into my conversion.
Thanks
Elec
Old Nov 3, 2006 | 05:57 PM
stealth71's Avatar
If you go to -4 you will probably have problems w/ clutch dis/engadgement because the amount of fluid that will have to be moved. Just a consideration.
Old Nov 4, 2006 | 09:04 AM
Project GatTagO's Avatar
McLeod makes a fitting for just that.
Andrew
