Building a dashboard
Old Nov 21, 2006 | 07:07 AM
Brains's Avatar
I used 5%, which needs a pretty darned bright LED to shine through well enough to be seen in daylight. If I were to do it over, I'd probably use 15%
Old Nov 21, 2006 | 09:16 AM
Quick Double Nickel's Avatar
Can you dim the LED bulbs?
Old Nov 21, 2006 | 10:17 AM
Brains's Avatar
Yes, they dim just fine with the regular control.
Old Nov 22, 2006 | 11:39 AM
G-Body's Avatar
sawzall wielding director
What brightness LED`s did you use? How many did you put in each gauge?
Old Nov 22, 2006 | 12:09 PM
Schitzo's Avatar
very nice work Brains.
Old Nov 22, 2006 | 12:46 PM
Brains's Avatar
Thanks Schitzo...
There's one LED in the 2-1/6" gauges, and three in each 3-3/8" gauge. The LEDs are 3mm 15,000 mcd .. I hit each one with a grinder to scatter the light for better distribution, and it works great.
Old Nov 23, 2006 | 03:54 AM
Gen3Benz's Avatar
looks great!
what impedence resistor did you solder in series with the led's?
Old Nov 23, 2006 | 04:00 AM
nycab's Avatar
looking nice. If custom gauges weren't so pricey, I'd probably go a similar route. As it is, I'm using the stock vette cluster. those things are prett nice imo.
Old Nov 23, 2006 | 11:22 AM
Brains's Avatar
These LED's actually came with a pack of resistors. You'd want to make sure the value you use matches the LED you're using. Break out the Ohm's law, look up the current across the LED (usually on the package), and figure out the right resistance for the voltage you intend to run.
Old Feb 3, 2007 | 02:37 PM
Hey Brains, what are the rough dimensions of the gauge panel you made? (12" x 16"?). Thanks.
