lt1 to ls1 swap
Old Nov 6, 2006 | 05:34 PM
4g63talon's Avatar
Default lt1 to ls1 swap
Hey guys, new to forum I have a 95 z28 with the stock lt1 and 4l60e. I was wondering if anyone had done a complete ls1 and t-56 swap? I was wondering what all I would need to do it. I have access to the engine and trans., I have heard that a corvette fuel rail is needed to compensate for the return fuel system on the lt1. Just curious of anything else I may run into before starting. The engine in the car now is about to hit 200,000 miles, it has been a good one, but I have been a fan of the ls1 since it came out. Thanks for any help.
Old Nov 6, 2006 | 08:08 PM
that240guy's Avatar
much easier and more cost efficient to sell your lt1 and buy an LS1 car. Most people that contemplate swapping lt1 to an ls1 are people that already have thousands of dollars invested into their car and don't want to cut their losses. If your car is stock, sell it and buy a 98+
Old Nov 6, 2006 | 10:12 PM
TwoFast4Lv's Avatar
My biggest question is how to run the dash I want to keep my stock dash.
Old Nov 7, 2006 | 10:32 AM
firebird6786's Avatar
thats my concern too, is there a harness out there that is plug N and go?
Old Nov 7, 2006 | 11:26 AM
that240guy's Avatar
There is no plug and play adapter, but GM is smart enough to keep everything the same color for the most part. If you get a couple wiring diagrams, making all the instruments work is fairly easy.
Old Nov 7, 2006 | 11:41 AM
does anyone in ls1tech have a diagram, pictures, anything that helped for wiring(electronics is my main concern) from when they did their conversion?
Old Nov 7, 2006 | 07:08 PM
that240guy's Avatar
whenever I do swaps, I just use factory GM manuals. Most dealerships will let you borrow their paperback manuals as they now use their own online programs.
Old Nov 7, 2006 | 07:35 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
We offer a full plug and play conversion on the factory LS1 harness into the LT1 F-bodies. All gauges work, etc.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Nov 9, 2006 | 07:23 PM
4g63talon's Avatar
Thanks for the advice, i'm really glad to find out that there is a complete harness available to keep all my stock guages. Does anybody know if there is alot of cutting involved when installing the t-56 into an automatic car?
Old Nov 12, 2006 | 05:53 PM
Sandmann120's Avatar
About the only cutting you are going to have to do is to cut a hole for the shifter to poke through and drill a hole for the clutch master cylinder.
Old Nov 13, 2006 | 05:03 PM
AllaboutdaZ's Avatar
thank god since i am getting ready to do this as well for a buddy of mine
Old Nov 13, 2006 | 05:10 PM
4g63talon's Avatar
Default manual swap
Thanks for the info, is good to know that not much cutting is required. This may be a stupid question, but, is it ok to run the ecu for an automatic? Do I need to find one out of a manual? Just wondering, thought it may cause ses light to come on.
ex-SS-ve's Avatar
the swap itself is easy . a lot of people make it seem difficult. mine was pretty involved and a lot of attention to detail went in as well. but i still retained my factory 96 lt1 gauges. the vette fuel rails are not needed. you can use the dead head setup. i had my way with it
Old Nov 13, 2006 | 05:27 PM
kwkenuf's Avatar
You can reuse your stock PCM and it will start and run but you will need to have it re-flashed for a manual trans. Otherwise you're going to get a whole lot of codes when the PCM doesn't hear from the tranny.....
