S13 Ls1 Swap?
Old Nov 6, 2006 | 07:09 PM
redws6's Avatar
Default S13 Ls1 Swap?
I just got a 240 and I would like to put a LS1 in it . I have never done a swap like this before so I was wondering if yall could tell me how I can do the swap and where can I get the parts from to do it?
Old Nov 6, 2006 | 07:22 PM
camarojunky74's Avatar
well it all depends on if you plan on keeping the engine efi? if not edelbrock makes a great intake and carb setup with all the wiring, and you are definaetly gonna need a bigger fuel pump one that provides the correct flow, then i would find out the dimennsions of the fuell lines on the f cars and then duplicate that onto yours, and you are probably gonna need a good 10 bolt or better!
Old Nov 6, 2006 | 07:40 PM
JD_AMG's Avatar
heres a start:
http://www.hinsonsupercars.com/
Old Nov 6, 2006 | 08:40 PM
icantdrift's Avatar
Originally Posted by JD_AMG
don't waste your money. not even his "bolt in" kit fits worth a damn and the price is astronomical for what you actually get.
redws6, i'd suggest you search around this forum a bit. you will find most of the info clear as day as to how a few of us have done the swap. it's not super easy but if you have a bit of fabrication skill then you should be able to follow pretty easily.
Old Nov 6, 2006 | 11:46 PM
Sonofagun's Avatar
http://www.ziptied.com/forum/viewtopic.php?t=8093
Check out this thread. The LS1 content starts on the second page.
