Fuel EVAP needed?
Old Nov 14, 2006 | 12:39 AM
LS1_4seater's Avatar
Default Fuel EVAP needed?
I have an LS1 going in a non emissioned off road car is the fuel EVAP solenoid needed? Thanks
-Derek
Old Nov 14, 2006 | 12:50 AM
bczee's Avatar
yes and no...
Yes if you want to want it to handle the fuel vapor and you are not using a Charcoal canister to remove the fuel vapors.
you can remove EVAP and plug it if you are not worried about the vapor (not really a good Idea). If you remove it, you can setup a Charcoal Canister to remove the fuel vapors.
