venting fuel tank?
Old Feb 9, 2008 | 12:00 AM
  #41
G-Body's Avatar
sawzall wielding director
I am using the 85 El camino tank so I do not have the second 'evap emissions canister vent valve'. I just have the purge valve.
Since you are using the f-body tank you really need to hook up both valves.
Old Nov 4, 2011 | 02:42 PM
  #42
jljude's Avatar
Default tank venting
Originally Posted by NSTY WS6
I was wanting to clean up the top of the intake on my ws6 and remove the vent system. Then i realized the car would have a gas vapor always around it, in the garage that wouldn't be good. I'm still debating.
If 350SS was to put a bulkhead fitting in the top of the tank and use maybe -6an or -8an braided line, coiled it around twice(to keep any fuel from splashing out) then ran it closer to the outside of the car and somehow secured the line. Would that be adequate enough to vent the tank for a) filling the tank. and b) the car running(i.e. useing fuel) ?
I used this method on a race car, but not street driving, and it was only a 10 gal. fuel cell..
How did you run your vent? did you put an evap on or just coil the line? do you smell fumes?
