LT1 to LS2 conversion
Old Nov 17, 2006 | 12:00 PM
mikez28_mjf's Avatar
Default LT1 to LS2 conversion
Does anyone know what is involved to swap an LS2 motor into an LT1 F-body? I did some searches on the net but I really didn't find too much.
Will an A4 from a 97 bolt up to the new LS2?
Any other major changes or problems?
Thanks!
Old Nov 17, 2006 | 04:41 PM
hockos's Avatar
Default keep all you old parts
yes we have transplanted a ls1 418 into a corvette lt1 and had problems with flywheel ls1 and ls2 have a larger flywheel so you will have the same problem, is the engine fly by wire throttle ?. also engine mounts need a bit of work, you have lots of room so you should have a easy time with it. good luck.
www.hockingracingshop.net
Old Nov 20, 2006 | 09:43 AM
thanks for the info.
The engine is just the GM crate motor that comes without the cable throttle body. What are my options with that?
