LS1 PS pump or orig Chevelle pump?
Any info is appreciated.
I would use whatever pump goes with the belt setup you're using (C5, f-body, truck, CTS-V, GTO, aftermarket) because engineering / building the bracketry to work with a serpentine belt setup is more difficult than any of the other concerns (hoses or pressure) I would have.
Hoses are pretty easy. The high pressure (pump to box) feed needs to be a high pressure hose. So, a factory hose will work, but you're unlikely to find one that fits properly (length, fittings, etc). I had good success with Russell's new braided stainless power steering hose & fittings on my Bravada. Bought the appropriate adapters for the pump and box, 2 90 degree ends, and a 3' length of hose from summit. Everything worked out just fine. Return hose is under low (relatively speaking) pressure, so you should be able to buy that hose at your local parts store (may end up with high pressure fuel line) and some hose clamps.
If necessary, you should be able to drop the output pressure by tampering with / replacing the spring that regulates the pump pressure (it's on the pump). Not sure how to do that, but I've seen reports of people doing it. On my Bravada, the C5 pump seems to put out about the right pressure. Steering effort might be just a shade light, but close enough that I'm not going to mess with it at this point. Maybe later.
'JustDreamin'
