69 Chevelle Swap
Old Dec 1, 2006 | 02:14 PM
69malichevelle's Avatar
Default 69 Chevelle Swap
I am looking for some information about how I would go about swapping LS1 or LT4 into my 1969 Chevelle Malibu? I wanted to know mainly what kind of mechanical to electronic part swaps I would have to make to get the thing to work.
I would also like to know some technical information on the blocks, cid, hp, tq, ect. One concern is... If I cannot afford to swap all of the electronics is it possible to turn this block into a Carbed engine instead of fuel injection (I ask because I have seen LS1/LT4 short blocks for sale moderately cheap)
I am not to familar with chevy engines because Im just beginning in the car world so I would apprciate any information you can give me... thanks.
Old Dec 1, 2006 | 03:26 PM
stealth71's Avatar
Well not to be mean, but use the search button and start some research. Google for "LS1 specs", "LS6 Specs" ... There are quite a few A-body swaps on here. My link is in the sig. I would keep the EFI and you can get a LS1 w/ alll accesories, PCM and harness for ~$2500. Fuel injection is a wonderful thing and a aftermarket 350SBC EFI kit can cost $2000.
Look through the FAQ too. There is tons of info here. Ask more questions after reading and searching.
Old Dec 2, 2006 | 12:16 PM
mullenh's Avatar
You better read threads on this. There is a lot involved. It should not be considered a 'Swap' it is more like re-engineering the car to accept the new engine. Unless you happen to have fabrication skills and some expertise in this engine I would not recomend you tackling this. I did mine but I own a repair shop and we build race cars.
