5 Volt from PCM
Old Dec 10, 2006 | 03:50 PM
bczee's Avatar
Default 5 Volt from PCM
I need a 5 volt source to power my VSS (Viper T56) and would like to see if I can get the PCM to power it on. Anyone know which Pin I might be able to use ?
Old Dec 10, 2006 | 03:58 PM
99c5vert's Avatar
Wouldn't any 5V from a 3 wire sensor work? Like TPS or MAP?
Old Dec 10, 2006 | 04:41 PM
Happy Jim's Avatar
On a 2000 PCM, Red connector,
Pin 20 (Lt Grn/BLK) = VSS Reference Low.
Pin 21 (PPL/WHT) = VSS Signal.
Any use?
Jim
Old Dec 10, 2006 | 08:29 PM
svt's Avatar
svt
isn't low ref ussually ground? I needed a 5V for my vats bypass module. i used on of the unused gray wires, most of those seem to have +5 volts. Don't recall the exact pin number I used though.
Old Dec 10, 2006 | 10:46 PM
bczee's Avatar
Thanks.. and sorry.. I should have stated I have a 99 PCM..and trying to get some VSS output to drive a Speedo.
The Viper VSS sensor generates a different signal and is not compatiable with the GM Signal. My other option is to try and machine some sleeve or adpater to use the GM VSS Sensor as the Viper VSS is larger in size.
I think the 99 and 00 PCM are the same ?? guys ?
I removed most of the unused pin/wire.. I will have to which one I can readd ?
Old Dec 11, 2006 | 11:36 PM
bczee's Avatar
I am using pin #46 to get a 5v source.. that is one thing i need.. will wire it up next, but will have to see about the conversion of the singal to a GM VSS.
let you guys know next time
