LS1 into an LT1 car.
Old Dec 11, 2006 | 01:09 AM
Daez's Avatar
Default LS1 into an LT1 car.
Is there any list of parts needed for this swap? I am now being somewhat pressed for time on this.. What would be the better route, buying bare block/heads, and having it rebuilt with a cheaper 383 kit, or maybe just forged 350.. or buying running ****. I'm seeing bare blocks for around 300, and bare heads for as low as 200. How much would I be looking at(big range approximates are ok) to fill those up? I wont be able to build it myself, or install it. I can play with other **** though. Assuming I can find decent deals here on ls1tech, is it realistic to swap one in for 3,000 or less? I've also seen longblocks for around 900-1200 on occassion..
What are some of the more expensive items I will have to be buying for this swap?
So far I am understanding...
Block/heads(seeing for around 900-1200 sometimes)
Intake(75 for ls1, 300-350 for ls6)
PCM/harness(500?)
Fuel system(rails, pump, blah blah),
K-member(I think?)
Ignition(coilpacks, etc.)
Water pump
pullies, and bs..
TB
Well, I'm a moron, so any good write-ups on this? Or at least a good point in the right direction?
as you can see, I am quite lost.
Old Dec 11, 2006 | 12:27 PM
shifty`'s Avatar
Buying complete setup is cheaper (hands down) than buying something bare and buying all the sensors and other peripherals.
Old Dec 11, 2006 | 11:07 PM
Daez's Avatar
Hmm, any more thoughts on this? or any links?
Old Dec 13, 2006 | 06:20 AM
JC93Z's Avatar
I bought my 5.3 out of a truck with computer, harness, and everything else to hook it up for $500. I have about $1300 in fuel stuff, just because I am going to a turbo 6.0 later and I didn't want to have to change that, but you should be fine with the stock fuel pump and lines. I bought a pro-fab tubular k-member with ls1 motor mounts and tubular a-arms for $475. BMR also makes a nice one. If I am not mistaken I think the stock ls1 k-member will bolt up into an lt1 car. So I think it is possible to swap it all in for under $3000.
Old Dec 13, 2006 | 06:17 PM
Tiago's Avatar
buy the entire setup out of another car.
fuel system is ooptional, ,you could just add a regulator and use your std LT1 lines/pump.
LT1 radiator and fans is ok.
Old Dec 13, 2006 | 06:21 PM
01WS6/tamu's Avatar
Buy another car, Take it from someone who has done this before. You will be money ahead.
