LS6 Supra
Old Jan 4, 2007 | 12:38 AM
suprabo's Avatar
Default LS6 Supra
this looks sick...
http://www.supramania.com/forums/showthread.php?t=10250
Old Jan 4, 2007 | 12:39 AM
phoenix's Avatar
you have to sign up for view that pics
Old Jan 4, 2007 | 12:42 AM
suprabo's Avatar
didn't think about that until after the post
Old Jan 4, 2007 | 01:21 AM
Turo's Avatar
Can you rehost some of the images here or something? I'm curious how its turning out.
Old Jan 4, 2007 | 03:49 AM
1dirtyZ's Avatar
yeah, what he said
Old Jan 4, 2007 | 07:28 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Host the pics.
Old Jan 4, 2007 | 09:54 AM
deejaydaze's Avatar
It's worth the 14.6 secs it takes for registration
For you lazy bastards.......
Register cuz he's not done yet and this took a long *** time!!
Old Jan 4, 2007 | 07:19 PM
dwarmenzerk's Avatar
thanks, im one of the lazy ones!
Old Jan 4, 2007 | 08:56 PM
SySt666's Avatar
Hehe, that is my car. deejaydaze, thanks for hosting those pics. I have decided now to get a cardomain site to put pics and updates on as not only SupraMania members may want a look.
Old Jan 4, 2007 | 09:06 PM
PRAY HRD's Avatar
that's really nice........but more pics of the girl please!!! lol. no really, i mean it.
btw.....nice build up there, should be pretty light i would think.
Old Jan 4, 2007 | 10:04 PM
sciff5's Avatar
actually from what my buddy said who has a 89 supra his supra is even heavier than the new ones which are like 34000lbs
Old Jan 4, 2007 | 10:27 PM
SySt666's Avatar
Should be pretty light compared to stock MKIII Supra. The engine/trans setup weighs about 100lbs LESS than the factory turbo setup. Not to mention the car will stay mostly stripped... I am guessing a little over 3000lbs.
Old Jan 4, 2007 | 10:30 PM
Plus 1 there.
Old Jan 4, 2007 | 10:37 PM
iGoRa's Avatar
even a girl can do LS swap
Old Jan 4, 2007 | 11:19 PM
Nine Ball's Avatar
LS1Tech Co-Founder
use www.fquick.com instead, it is much better!
Old Jan 5, 2007 | 02:43 AM
macky's Avatar
The Supra owner is not a girl. The girl in the pics is the owner's girlfriend. Same mistake happened on that other forum.
Old Jan 5, 2007 | 08:50 PM
WILWAXU's Avatar
Nice project.
Old Jan 8, 2007 | 10:05 PM
V8 Supra Builder's Avatar
Default A Gen 3 in a Supra? What a great idea!
Looks like a familiar fight .
Best of luck with the exhaust.
Just made up my AC hoses today & finally found a socket to tighten the oil pressure sender (LM7 installed in MK 3 Supra, yes it is TIGHT!).
I hope to have it running within a month...
Old Jan 12, 2007 | 11:41 PM
SySt666's Avatar
After trying F-Body and C5 exhaust manifolds, I found some that will work. They are off of a CTS-V. The clearance to the steering link on the driver's side is so close that when turning the steering wheel the pinch bolt rubs a little. So with some grinding it should JUST fit. I am not worried about much movement as I have polyurethane engine and transmission mounts... I will post some pics of that once I have the grinding all done.
I have been working on the engine harness and am about half-way done with it. After that it is time for the chassis harness. I also still need to actually make my transmission mount and weld up a cage to mount my fuel cell. After that I just need to weld up some exhaust piping and route the feed line to the fuel rail and the rear brake line. I plan on routing the brake and fuel lines through the interior.
Old Jan 13, 2007 | 09:42 AM
00turboT/A's Avatar
Looks good in there
