tow/haul/wiring
Old Jan 4, 2007 | 10:44 AM
hotrod51's Avatar
Default tow/haul/wiring
Anyone know how to wire the tow/haul function on a 04 6.0 4L80E swap?
Old Jan 4, 2007 | 12:49 PM
76LQ9TA's Avatar
I think it should just be a switch for the wire to the pcm. It will tell the pcm to use a different set of shift tables. Look at a service manual at the dealer to find which pin on the pcm goes to the switch. The manual I have is from an escalade so it doesn't show this.
Old Jan 4, 2007 | 01:02 PM
stealth71's Avatar
This has been covered before try a search. You need to temporarily ground a pin on the PCM to switch programs. The PCM must be reprogramed for this functionality first.
Old Jan 4, 2007 | 01:05 PM
stealth71's Avatar
Ok I found it for you, but search next time.
Dual Tune
