PCM A/C Fan question
I am working on an LS1 RX-7 that will have A/C from/controlled by the LS1 computer. I am going to run a single dual speed fan, and I just need to know if the PCM kicks the fan relay on when the A/c comes on or not.
If it does, then I am set. If it doesn't, I am going to have to work an extra relay trigger in for the fan.
Please let me know as I am working through this part of the wiring now.
Thanks
LS1
The PCM commands low speed fans on under the following conditions:
Engine coolant temperature exceeds approximately 108°C (226°F).
When A/C is requested and the ambient temperature is greater than 10°C (50°F).
A/C refrigerant pressure exceeds 1482 kPa (215 psi).
After the vehicle is shut off if the engine coolant temperature at key-off is greater than 113°C (235°F) and system voltage is more than 12 volts. The fans will stay on for approximately 150 seconds.
The PCM commands High Speed Fans on under the following conditions:
Engine coolant temperature reaches 112°C (234°F).
A/C refrigerant pressure exceeds 1710 kPa (248 psi).
When certain DTCs set.
If you are using an aftermarket system, you may wnat to contact them for their advice.
Pat
