Oilpan Comparison and Part Numbers
Old Jan 8, 2007 | 10:09 AM
Gm-LSX's Avatar
Default Oilpan Comparison and Part Numbers
GEN III
Camaro / Firebird "F"
Capacity: 5.5 qts
Oil pan , List Price $266.39: 12551581
Oil pump pickup: 12558251
Windage tray: 1258253
Dipstick tube: 12551577
Dipstick: 12551581
O-ring for Oil pump pickup: 12557752 (Same as Corvette LS1/LS6)
(insert Sketch here)
Truck "C/K"
Capacity: 6.5 qts
Oil pan: 12560393
Oil pump pickup: 12563961
Windage tray: 12558268 (same as CTS-V)
Dipstick tube: 12563918
Dipstick: 12558684
O-ring for Oil pump pickup: 12563963
Holden (Pontiac GTO, Vauxhall Monaro)
Capacity: 5.5 qts
Oil pan: 12561541
Oil pump pickup: 12572654
Windage tray: 12558189 (same as Corvette)
Dipstick tube: 12561544
Dipstick: 12562468 (same as Corvette)
O-ring for Oil pump pickup: ?
Corvette "Y" (Batwing)
Capacity: 6.5 qts
Oil pan,List Price 806.44: 12561828
Oil pump pickup: 12558750
Windage tray: 12558189 (same as Holden)
Dipstick tube: 12556405
Dipstick: 12562468 (same as Holden)
O-ring for Oil pump pickup: 12557752 (Same as Firebird/Camaro "F")
GEN IV
Corvette "Y" (not LS7)
Capacity: 5.5 qts
Oil pan: 12581810
Oil pump pickup: ?
Windage tray: ?
Dipstick tube: ?
Dipstick: ?
O-ring for Oil pump pickup:?
SSR & Trailblazer
Capacity: 6 qts
Oil pan: 12579203
Oil pump pickup: ?
Windage tray: ?
Dipstick tube: ?
Dipstick: ?
Corvette "Y" (LS7, Longer Pan and Front Cover)
Capacity: Dry Sump
Oil pan: ?
Oil pump pickup: ?
Windage tray: ?
Dipstick tube: ?
Dipstick: ?
CTS-V
Capacity: 5.5 qts
Oil pan: 12577901
Oil pump pickup: 12577906
Windage tray: 12558268 (same as Truck "C/K)
Dipstick tube: ?
Dipstick: ?
Oil pan baffle: 12577904
Camaro
Capacity: ? qts
Oil pan: ?
Oil pump pickup: ?
Windage tray: ?
Dipstick tube: ?
Dipstick: ?
2007 Truck
Capacity: 6 qts
Oil pan: 12609074
Oil pump pickup: ?
Windage tray: ?
Dipstick tube: ?
Dipstick: ?
Holden VE/Pontiac G8
Capacity: 6 qts
Oil pan: ?
Oil pump pickup: ?
Windage tray: ?
Dipstick tube: ?
Dipstick: ?
Hummer H3 Alpha
Capacity: 5.5 qts
Oil pan: 12614821
Oil pump pickup: 12608593
Windage tray: 12612728
Dipstick tube: 12612015
Dipstick: 12603506
Other
Long oil filter: ACDelco PN PF59
Short oil filter: ACDelco PN PF44
Oil Drain Plug (magnetic), List Price $19.32: 23011420
High Volume LSX Pump Kit, Pickup and seal included List Price $86.00: 17801830
Note: I'm working on clean Sketches for all GEN III oilpans
Last edited by Gm-LSX; Nov 28, 2007 at 12:33 PM. Reason: S10xGN's info added; O-Rings, Hummer H3 Alpha,
Old Jan 8, 2007 | 05:03 PM
Project GatTagO's Avatar
Check out Street and Performance's catalog for sketches of a few of the pans listed.
Andrew
Old Jan 15, 2007 | 01:48 PM
GIGAPUNK's Avatar
Any body know where the LS7 numbers are?
Old Jan 27, 2007 | 10:21 PM
S10xGN's Avatar
CTS-V
Capacity 5.5 qts
Oil pan 12577901
Oil pump pickup 12577906
Windage tray 12558268
Dipstick tube ?
Dipstick ?
Oil pan baffle (insert) 12577904
To the best of my knowledge...
Russ
Old Nov 27, 2007 | 03:05 PM
V8 Supra Builder's Avatar
I bought the H3 Alpha pan, tray, pickup, tube, and dipstick and found the tube I got was the wrong one (too long for the stick). Here is the PN breakdown if you want to edit your list:
Pan: 12614821
Pickup: 12608593
Deflector (windage tray) : 12612728
Tube: ??? 12612015 in another thread (I was sold PN 12563918 which shows above as fitting a truck)
Dipstick: 12603506
Old Nov 27, 2007 | 04:13 PM
http://www.s10forum.com/forum/f213/l...f-them-324366/
Old Nov 27, 2007 | 04:25 PM
rao's Avatar
rao
Hey, that thread looks a lot like this one
Old Oct 13, 2010 | 11:22 PM
chevymec's Avatar
Tagging this for later.
Old Oct 14, 2010 | 12:24 AM
bczee's Avatar
Isn't most of this information and pictures of the pan in the FAQ/Sticky.. if anything, the information should be used to update and add missing information.
