Source for weatherpack factory connectors?
Old Jan 12, 2007 | 05:15 PM
Zedzag's Avatar
Default Source for weatherpack factory connectors?
I'm doing the wiring on my project and need some junkyard help. I'm using the factory dual electric fans from a 98-02 camaro and aside from the factory fbody wiring harness, any other donor cars use the same connector for the fans? Most fbodie wiring harnesses stay with their engines.
Old Jan 12, 2007 | 05:57 PM
LS1MCSS's Avatar
If the motor pigtails are all you need, they are cheap ar rockauto.com.
Old Jan 12, 2007 | 07:36 PM
bczee's Avatar
You can check with one of the Sponser on the LS1TECH.COM home page..
If you can not find any, then just google or yahoo search on:
"gm oem connectors"
There are many, but we are not suppose to state there names if they are not a sponser on the site.
Old Jan 14, 2007 | 12:56 AM
Zedzag's Avatar
Thanks guys. I'll try those sources
Old Jan 14, 2007 | 06:44 AM
Gen3Benz's Avatar
You can build your own from a kit......
Or you can buy pre-assembled connectors.....
Links removed by mod. If everyone could refrain from posting links we would appreciate it. The sponsors pay to advertise here and it isn`t fair to them to have other companies get free advertisement.
Old Jan 14, 2007 | 04:12 PM
Sam88Gta1's Avatar
Find a 02-03 Buick Centry in a junk yard and remove the fan harness from it.
It has the two fan plugs with a 4 wire disconnect at the other end..pull the wiring all the way to the fuse box.
This will be enough wire to run two relays and have a quick disconnect on the fans so you dont have to pull both plugs each time you pull the fans.
This harness with two sealed relays cost me $12.
Attached Thumbnails Source for weatherpack factory connectors?-truck-001.jpg   Source for weatherpack factory connectors?-truck-002.jpg   Source for weatherpack factory connectors?-truck-004.jpg
Old Jan 14, 2007 | 11:30 PM
Zedzag's Avatar
Thanks Sam. Very handy source.
Gen3 - I snagged what I needed from one of your deleted sources and added it to my favourites. Thanks.
