LT1 in a 1980 Vette
My dad needs his old man Vette, and he loves the 1980 model's body, but I don't want to give him a vette that only looks good. I'm looking at turning the thing into the Batmobile, but the first step is replacing that weak engine Chevy dropped in there for fuel efficiency and emmissions. With upgrades to the engine and suspension, it should have a vastly improved ride with 350-400 rwhp moving him along and grabbing all the looks with that jet intake hood and bat-winged rear fenders.
Any info and input is much appreciated!
Being that the LT1 is a Gen II SBC, all should drop right in and everything should bolt up with out a problem. You would only have to modify the Wiring Harness and Fuel System to handle EFI requirement of fuel pressure, return line and regulator.
You might have to get the computer reprogramed if needed.
Shouldn't be to much harder, same applies (Fuel, PCM and wiring), just have to deal with new engine and Trans mounts. There has been many GenIII engine swaps into the C3.. search on the C3 swap and maybe they will ping in on this thread to give you some info...
Add some Updated suspension (C4/5) and it will be a great car..
Do it and you will not reget it... ! keep us posted !
