o2 sensor question
Old Jan 15, 2007 | 12:11 AM
79mike's Avatar
Default o2 sensor question
Hey guys, not sure if this goes here or in the tech threads or what but here goes... Im doing a ls1-t56 swap into my 79 camaro, and was wondering if you guys kept your o2 sensors or not? if you did, why?
Old Jan 15, 2007 | 12:24 AM
bczee's Avatar
I am only using the front O2.. had the Rear O2 flashed out of the PCM along with other codes not required in my swap.
Old Jan 15, 2007 | 08:31 AM
RFERG43's Avatar
The LS1 computer needs the front O2 sensors to monitor air/fuel ratio.
Old Jan 15, 2007 | 10:50 AM
79mike's Avatar
ah ok, then Ill definately have to keep them. Thanks guys!!
