IRS solutions?
Old Jan 17, 2007 | 10:02 PM
99c5vert's Avatar
Originally Posted by sb427f-car
Problem with inboard breaks on these cars is where do you put the fuel cell? There ain't much room back there to begin with, add brakes on the inside and where is it gonna go?
Belongs to RDROCKT http://www.usa7s.com/forum/forum_posts.asp?TID=509
Old Jan 18, 2007 | 07:12 AM
chuntington101's Avatar
sbf427f-car go look for a GTO rear end. will have everything you need mate. also will be more than strong enough for you. if you really want to get technical than you can fab up some wishbones/trailing arms no problems!
alternatives include 3series BMW stuff.
IRS is the best solution and is whats used over here alot.
thanks Chris.
PS while your looking at the GTO, get engine and box to! lol
Old Jan 18, 2007 | 07:19 AM
also sbf427f-car take a look at what Pete has done.
https://ls1tech.com/forums/conversions-swaps/460867-ls1-into-vauxhall-astra-coupe.html
thanks Chris.
Old Jan 18, 2007 | 09:23 AM
sb427f-car's Avatar
SSU'S Vice Mod
If gear ratio selection is a factor, nothing will beat a diff out of a Cobra or Explorer. The housings are different but the guts are ideantical in both rears. The internals are the same as solid axle 8.8 rear ends and use 31 spline axles. There is huge aftermarket support for these rear ends with all kinds of diffs being offered along with just about any gear ratio you may need. Stock 03-04 ratio is 3.55, not sure about the Explorers.
Andrew
Thanks Andrew...
Old Jan 18, 2007 | 09:31 AM
sb427f-car's Avatar
SSU'S Vice Mod
thanks Chris.
That's also a posibility. What center sections do the CTS and GTO use?
Old Jan 18, 2007 | 09:37 AM
sb427f-car's Avatar
SSU'S Vice Mod
Hey 99...what advantages are there to getting the breaks inboard like that? I realise that it gets them off the corners so you're reducing corner weight but then you complicate cooling (which putting vents and ducting to them wouldn't be that big of a deal I suppose).
Is there something else I'm missing?
Old Jan 18, 2007 | 05:30 PM
99c5vert's Avatar
Main advantage is less unsprung weight = easier to keep the wheels on the ground in bumps. You are right, that it's harder to cool, but sevens are not particularly hard on brakes.
Old Jan 18, 2007 | 06:40 PM
sb427f-car's Avatar
SSU'S Vice Mod
No, I know they aren't...what is it that Champion / Chapmen preach, add lightness.
Hum...I had not considered that for added traction ability, but it makes sense. Great...way to throw another wrench into my planning works
Old Jan 18, 2007 | 06:47 PM
99c5vert's Avatar
I'd put that at the bottom of the list. A novel feature, and nice to have, but I'm not sure if it's worth doing alot of custom stuff.
Old Jan 18, 2007 | 07:10 PM
sb427f-car's Avatar
SSU'S Vice Mod
Yeah, the ideas list keeps growing and nothing is getting crossed off.
