Done with install, need help troubleshooting
Here is a link to everything that the program will tell me if I get the upgrade...
http://www.autotap.com/enhanced_parameters_gm.asp
Would that help?
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
John, is it at all possible that I could have a bad sensor, or a shorted sensor or something that for some reason doesn't trip a code even though it's bad? I'm tempted to get a list of each sensor that could possibly make the engine not run, and start replacing them. I'm at my whit's end here, and I don't know what else to do. I don't even feel like I can take it into a local shop because I'm afriad that they're just going to charge me hundreds of dollars, not find the problem and I'll still be nowhere. Oh, and don't at all feel like I'm mad any anyone here, especially you John. I'm sure we'll figure this thing out, and I know this sucks for you since you're a busy guy anyway. I'm mainly just frustrated because I don't know what else to do.
My other thought is that I could pull the harness back out, and hook up only the wires that the engine NEEDS to run. Like power straight from the battery, ground from the battery. Fuel Injectors, the sensor or two that It needs, and then try it that way so I KNOW I don't have a stupid cut in the wires or something wired wrong. I suppose with that in mind, I could just start unhooking everything that it doesn't need and that might be easier. I would think that it would blow a fuse if I cut a wire and it's shorting out. Let me know if anyone has any other ideas. I suppose we should try the computer swap before I start getting too angry with the thing
.Thanks again!
Mike
Ide say try another PCM...especially if John is agreeing to swap it out for ya or something. Sounds like your best option before you go trying to replace sensors. Get the "new" PCM, double and triple check all of your connections and make sure all the sensors are correctly installed.
The fact that the injectors are working, then seconds later they are shutting down...sounds like a clue that something may be screwy in the PCM, and VATs is still taking over. Just weird... Keep us posted.
Justin
At first when I started the engie after changing the computer it ran like a champ. I let it idle for about 30 seconds just waiting for it to die. It never did, so I turned it off and figured I'd just double check the fluids before I let it go much longer than that.
I checked everything and tried it again and the 2nd time I started it up it immediately goes back to it's old habbits. about 1 second of run time and it cuts the injectors.
So I haven't had a chance to hook the new computer up to the scanner yet, but I'll do that later tonight and see if I can get a code from it. We'll see.
Put some water in the sink... Hold a cross over it and say a few prayers. Then...go light some candles in the garage, and while chanting praise to the LS1 gods, sprinkle the water all over the car and engine. The idea is to try to purge the "fix or repair daily" demons from the entire vehicle.
Haha.. ok. Sorry...
Thats really weird man. Almost sounds like an intermittent circuit failure in the main harness. And when you swapped the PCM it connected just right to work. Then after shutting it down and trying again the connection was broken again. This is definetly a goofy issue...
Justin
Is there any way to get the computer to tell me anything about why it's having this issue... maybe through the OBDII port? I tried asking it directly, and it just sits there with a blank stare.
Thanks!
Mike
again i asked the guy who helped me install mine, a shop mechanic
Okay, I'm out of other ideas. Can somone tell me how hard it is to replace the camshaft position sensor? I think my next step is to just replace that darn thing.
I just got back from a week's vacation and I'm ready to pound on it some more...
The one thing I've thought of is that maybe the accelerator pedal isn't functioning correctly. I heard somewhere that there are several resistor banks in there and if any of them read off then it will shut the engine down to make sure that it doesn't get into a WOT condition. Can anyone tell me what happens to your engine when you simply unplug the throttle pedal and try to start it? Also, perhaps a way to test the pedal.
I thought I saw somewhere online that I could download the factory LS1 repair manual. Anyone remember where that was? I thought I'd start checking some sensors and anything I can with an ohm meter.
Thanks!
After a few minutes the throttle (pedal) stops working.....no blade movement.
Codes are 101 (MAF sensor performance).
I've used two MAF's, so I don't think its broken...wires are OK, too (speartech harness)
What are your thoughts....what is going on?
Jon the Newbie
I have no idea what to tell you. Could be a computer problem, or could be a bad resistor in the pedal or something too.
Here is what I did.
I got the new computer from speartech, and plugged it in, it ran for 2 mins... I thought the problem was fixed. I checked fluids and started it back up. Same old problem. Ran for 3 cycles and turned off. Tried again and again, nothing different.
I had a week long trip I was leaving on in the morning. I just left everything plugged in and it sat there for about 10 days w/o me doing anything. Eventually I thought I'd try it again to see if anything was different. I had noticed before that after I let it sit for a little while, it would run longer sometimes, so I thought I"d try it.
It ran fine, and never has had the problem since. I now have about 1000 miles on it and it still runs great.
All I can figure is that whatever issue it was it needed time to burp itself or something and when I'd try to start it, it would reset it. Makes no sense.
But that's my story, and at least it's running now.
