Progress on the LSX Harness Conversion
As far as the Fuze, it is the PCM Ignition circuit. What I think caused it is that the grounds for all that stuff in the Harness were not grounded cause they bolt to the back of the Drivers side Head on the LS motor., and no Tranny was connected up.
Hey Rhino, if you read this, I think it is that. I know I mentioned it up there. If it isn't, it's one thing out from narrowing it down, but I think it is. The one ground on the Chassis was for the PCM itself, but all the major stuff(Ignition, Injectors, Trans, etc..) was not grounded.
The hard part is done, just a little bit of trouble shooting now. All I need is the Motor...
