clutch cable
Old Feb 10, 2007 | 01:30 PM
prdtr15's Avatar
Default clutch cable
With an ls1 with a t56, it has a hydraulic slave/master on gms, but can it work with a cable clutch set up?
Old Feb 10, 2007 | 01:43 PM
USA-1's Avatar
The Slave cylinder is hydraulic.
So you would have to get a different bellhousing, along with a clutch fork and Throwout bearing. I don't think any of those parts exist for an F-Body T56, so I don't believe its feasible.
Look into it though, might be some aftermarket company that makes a conversion kit for retrofitting T56's in older cars or something.
Old Feb 10, 2007 | 04:47 PM
prdtr15's Avatar
ok, well changing over to a hydraulic system isnt hard, guess i'll just have to do that. thank you
Old Feb 11, 2007 | 07:23 PM
USA-1's Avatar
I looked into the 03-04 Mustang Cobras that use the T56 transmission, and it looks like they have a cable clutch setup. Might want to look into that, I'm sure its cheaper and easier than doing a hydraulic setup
Old Feb 11, 2007 | 07:43 PM
prdtr15's Avatar
hmm, i'll have to check their set up and compare to the f bodies
