does anyone know specific differences 02 Fbody vs. 04 Goat?
Old Feb 14, 2007 | 01:31 PM
mumzer's Avatar
Default does anyone know specific differences 02 Fbody vs. 04 Goat?
im looking at motors for the swap...does anyone have hard data on the differences between the two. Bear in mind I'll be attempting to get through california referee process, so simplicity of packaging is as important as output in my 2500lb chassis.
i know the f body brackets will work. I know they are both cable throttle. curious about cam specs, air injection pump engine configuration etc.
many thanks
Old Feb 15, 2007 | 09:41 AM
Jones'n's Avatar
Pretty sure the '04 GTO did not have EGR or Air Pump. The '02 Camaro would have had both.
Old Feb 15, 2007 | 09:52 AM
mumzer's Avatar
actually 02 camaros dont have egr....just the air pump.
thanks
Old Feb 15, 2007 | 06:37 PM
downset71's Avatar
04 gto has no emissions except for gas vent purge valve
Old Feb 15, 2007 | 09:34 PM
bczee's Avatar
What car are you putting it into ?
Oil is front slump on the GTO and the rear for the F-Body
Old Feb 15, 2007 | 09:55 PM
ChucksZ06's Avatar
Are the front brakes the same?
Old Feb 18, 2007 | 11:32 AM
Widetracker's Avatar
No brakes are completely different. Wheel pattern is even different.
