LS1 into a 240SX.
Old Feb 14, 2007 | 01:47 PM
Sonoma95SS's Avatar
Default LS1 into a 240SX.
Might be going with the El Es Juan instead of the 302 swap in my 240SX, gonna cost more to beef the car up than the motor and tranny cost
There's no way I'm buying the $4k kit I see online. That's just crazy!
Old Feb 14, 2007 | 02:02 PM
carado1984's Avatar
ls1 weighs less and 300+ rwhp out of the box.
Old Feb 14, 2007 | 02:21 PM
cnichols's Avatar
I test fit a 302 in an S14...stick with the LS1. Way better fit and more power. Better looking too.
Sonoma95SS's Avatar
Even the 302 with aluminum heads weighs less than the stock 2.4L in the Nissan. Did my homework on that part. I'm just hoping the stock rear end holds up. It's supposed to stand up to 400 HP but who knows if it will.
Old Feb 14, 2007 | 02:23 PM
Sonoma95SS's Avatar
When the heck did you move to STL? Last time I heard from you was when you lived down in MS and wanted to buy my car.
Old Feb 14, 2007 | 07:35 PM
memphiss13's Avatar
a 240 rear end can handle alot more than 400hp. i see you finally saw the light quas
Old Feb 14, 2007 | 08:04 PM
cnichols's Avatar
I think you've got me mistaken for somebody else....I've always lived in KY until a year ago.
And, like memphis said...don't worry about the rear. I'd put the Nissan diff up against anything else of a similar size. It's held 500+hp on numerous cars for extended periods of time.
Old Feb 14, 2007 | 10:44 PM
datboibrad's Avatar
nissan diff has held up to 1000whp (welded) the only weak points on the rear end is the welded seems (which can crack due to rust and to many clutch kicks) and the poly bushings. and of course axles. other than that it clowns most rear ends.
