92 s-10 ls series info
thanks, sorry if i am dragging up old info.
don p
The biggest frame differences are between 2wd and 4wd. 2wd you can notch the frame. 4wd you need to relocate the AC compressor.
Best accessory solution is the vette stuff (C5 or C6). The f-body stuff puts the alternator in the Power steering box. Moving the engine up so that the alt clears is a bad idea. The truck access can be made to fit, but you loose space up from up front, meaning you'll have to push the radiator forward.
With AC, you'll want to run puller fans. They work much better than pusher fans (fans pull air through the radiator & AC condenser much better than they push). Theres a reason GM doesn't use pusher fans.
Good luck.
'JustDreamin'
