power steering pump specs
Old Mar 4, 2007 | 09:36 AM
pugwash's Avatar
Default power steering pump specs
despite much searching i have been unable to find out anything about the LS1 power steering pump. Can anyone tell me the usual flow rate and the set pressure for the pump. Really realy really need this information for my hybrid!
on a completely different note does anyone have a part number for the quick connect fuel line connectors so that i can make ends to match?
Old Mar 4, 2007 | 10:16 PM
IOwnCalculus's Avatar
I don't have a hard source for this but I remember coming across 1500 PSI for the stock LS1 pump, as opposed to the roughly ~1200 PSI for an old GM pump. Judging by steering feel I'm inclined to think that number is correct.
If I could find a way to underdrive just the power steering pump (in AZ, I'm not about to gimp out on my water pump or alternator!) I would because I actually get the feeling that the pressure is occasionally pushing the steering a bit one way or the other when I truly romp on it.
